Ana içeriğe geç
Vornado 133 Compact Air Circulator Fan Blade Replacement
Neye ihtiyacın var
  1. Vornado 133 Compact Air Circulator Fan Blade Replacement, Grill Cover: adım 1, 3 resimden 1. Vornado 133 Compact Air Circulator Fan Blade Replacement, Grill Cover: adım 1, 3 resimden 2. Vornado 133 Compact Air Circulator Fan Blade Replacement, Grill Cover: adım 1, 3 resimden 3.
    • Use a #1 Phillips screwdriver to remove the four 3mm screws.
    • It may be difficult to reach the bottom two screws; tilt the fan housing straight upwards for easier access.
  2. Vornado 133 Compact Air Circulator Fan Blade Replacement: adım 2, 2 resimden 1. Vornado 133 Compact Air Circulator Fan Blade Replacement: adım 2, 2 resimden 2.
    • Once the screws are removed, turn the fan back over. Use your hands to pull the front grill cover off.
  3. Vornado 133 Compact Air Circulator Fan Blade Replacement, Fan Blades: adım 3, 3 resimden 1. Vornado 133 Compact Air Circulator Fan Blade Replacement, Fan Blades: adım 3, 3 resimden 2. Vornado 133 Compact Air Circulator Fan Blade Replacement, Fan Blades: adım 3, 3 resimden 3.
    • Turn the center nut on the blade shaft clockwise to remove the nut, then remove the blades.
    • The nut is removed by turning clockwise, rather than the normal counterclockwise.
Sonuç
Erin Klein
483 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Liner Summer 2017 UW Tacoma, Team S1-G2, Liner Summer 2017 üyesi
UWT-LINER-SU17S1G2
4 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
Mi ventilador ya no enciende qué puede ser?
Fidencio Rosas - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 3,130
