Ana içeriğe geç
Vornado 133 Compact Air Circulator Fuse Replacement
Neye ihtiyacın var
  1. Vornado 133 Compact Air Circulator Fuse Replacement, Fuse: adım 1, 1 resimden 1.
    • Ensure the unit is powered off and remove the plug from the outlet.
  2. Vornado 133 Compact Air Circulator Fuse Replacement: adım 2, 3 resimden 1. Vornado 133 Compact Air Circulator Fuse Replacement: adım 2, 3 resimden 2. Vornado 133 Compact Air Circulator Fuse Replacement: adım 2, 3 resimden 3.
    • Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
  3. Vornado 133 Compact Air Circulator Fuse Replacement: adım 3, 3 resimden 1. Vornado 133 Compact Air Circulator Fuse Replacement: adım 3, 3 resimden 2. Vornado 133 Compact Air Circulator Fuse Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
    • The replacement fuse must be 2.5 amp, 125 volt.
    • Do not push against the glass center of the fuse, only the metal end pieces.
Sonuç
Follow these instructions in reverse order to install the new fuse and close the access panel.
11 farklı kişi bu kılavuzu tamamladı.
Erin Klein
483 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Liner Summer 2017 UW Tacoma, Team S1-G2, Liner Summer 2017 üyesi
UWT-LINER-SU17S1G2
4 Üyeler
4 adet Kılavuz yazıldı
10Kılavuz Yorumları
Great post! This saved me $60 from buying a new fan! Thank you!
jamiekim808 - Yanıt
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
TLCIMMORTAL - Yanıt
Fast-acting or slow-acting?
James Olsen - Yanıt
Wow, I was going to throw this fan in trash and seeing your instructions I saved it
Anupam B - Yanıt
thanks buddy, just bought the fan ,son stuck a pencil in it , Quick fix
BOBBY C - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 17
Son 30 gün: 117
Her zaman: 33,799
