Ana içeriğe geç
Vornado Duo Circuit Board Replacement
Neye ihtiyacın var
  1. Vornado Duo Circuit Board Replacement, Circuit Board: adım 1, 2 resimden 1. Vornado Duo Circuit Board Replacement, Circuit Board: adım 1, 2 resimden 2.
    • Start off by using a Philips #2 screwdriver to remove all 8 10mm exterior screws on the rear of the device.
  2. Vornado Duo Circuit Board Replacement: adım 2, 3 resimden 1. Vornado Duo Circuit Board Replacement: adım 2, 3 resimden 2. Vornado Duo Circuit Board Replacement: adım 2, 3 resimden 3.
    • Carefully take front panel off.
  3. Vornado Duo Circuit Board Replacement: adım 3, 2 resimden 1. Vornado Duo Circuit Board Replacement: adım 3, 2 resimden 2.
    • Loosen 5 mm screw at bottom of fan blade located inside the blades.
  4. Vornado Duo Circuit Board Replacement: adım 4, 2 resimden 1. Vornado Duo Circuit Board Replacement: adım 4, 2 resimden 2.
    • Remove fan blade after unscrewing top 2 screws located on each side of the covered board.
  5. Vornado Duo Circuit Board Replacement: adım 5, 3 resimden 1. Vornado Duo Circuit Board Replacement: adım 5, 3 resimden 2. Vornado Duo Circuit Board Replacement: adım 5, 3 resimden 3.
    • Remove cover from board.
  6. Vornado Duo Circuit Board Replacement: adım 6, 2 resimden 1. Vornado Duo Circuit Board Replacement: adım 6, 2 resimden 2.
    • Unsolder the circled spots on the mother board and resolder each wire to corresponding spot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler Pettenger
536 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Nance Fall 2017 USF Tampa, Team S1-G1, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 856
