Ana içeriğe geç
Vostro 1720 Memory Module Replacement
Neye ihtiyacın var
  1. Vostro 1720 Memory Module Replacement, Sliding the Latches: adım 1, 1 resimden 1.
    • Slide the battery lock latches into the unlocked position.
    FixBot'a Sor
    Yorum Ekle
  2. Vostro 1720 Memory Module Replacement, Slide the Battery: adım 2, 1 resimden 1.
    • Slide the battery toward the back of the computer to remove.
    FixBot'a Sor
    Yorum Ekle
  3. Vostro 1720 Memory Module Replacement, Remove the Screws: adım 3, 1 resimden 1.
    • Remove the eight screws from the access panel.
    FixBot'a Sor
    Yorum Ekle
    • Lift the edge of the access panel that is closest to the center of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Vostro 1720 Memory Module Replacement, Remove the Access Panel: adım 5, 1 resimden 1.
    • Remove the access panel.
    FixBot'a Sor
    Yorum Ekle
  5. Vostro 1720 Memory Module Replacement, Removing the Memory Module: adım 6, 1 resimden 1.
    • If applicable, remove the top memory module by using your fingertips to carefully spread apart the securing clips on each end of the top memory module connector until the memory module pops up.
    FixBot'a Sor
    Yorum Ekle
  6. Vostro 1720 Memory Module Replacement, Sliding the Memory Module: adım 7, 1 resimden 1.
    • Slide the memory module out of the socket.
    FixBot'a Sor
    Yorum Ekle
  7. Vostro 1720 Memory Module Replacement, Spreading apart the Clips: adım 8, 1 resimden 1.
    • If applicable, remove the bottom memory module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    FixBot'a Sor
    Yorum Ekle
  8. Vostro 1720 Memory Module Replacement, Sliding the Memory Module: adım 9, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Johnathan Hammond
46.158 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 324
