Ana içeriğe geç
Vtech InnoTab 3S Rear Panel Replacement
Neye ihtiyacın var
  1. Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: adım 1, 3 resimden 1. Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: adım 1, 3 resimden 2. Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: adım 1, 3 resimden 3.
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Rear Panel Replacement: adım 2, 2 resimden 1. Vtech InnoTab 3S Rear Panel Replacement: adım 2, 2 resimden 2.
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Rear Panel Replacement: adım 3, 3 resimden 1. Vtech InnoTab 3S Rear Panel Replacement: adım 3, 3 resimden 2. Vtech InnoTab 3S Rear Panel Replacement: adım 3, 3 resimden 3.
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Rear Panel Replacement: adım 4, 1 resimden 1.
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
Sonuç
Karina Garcia
824 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G2
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
too dumb i tryed 7 times it didnt work i reat this 1000000-/10
Kyron Ostrander - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 624
