Ana içeriğe geç
Vtech InnoTab 3S USB Port Replacement
Neye ihtiyacın var
  1. Vtech InnoTab 3S USB Port Replacement, Rear Panel: adım 1, 3 resimden 1. Vtech InnoTab 3S USB Port Replacement, Rear Panel: adım 1, 3 resimden 2. Vtech InnoTab 3S USB Port Replacement, Rear Panel: adım 1, 3 resimden 3.
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S USB Port Replacement: adım 2, 2 resimden 1. Vtech InnoTab 3S USB Port Replacement: adım 2, 2 resimden 2.
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S USB Port Replacement: adım 3, 3 resimden 1. Vtech InnoTab 3S USB Port Replacement: adım 3, 3 resimden 2. Vtech InnoTab 3S USB Port Replacement: adım 3, 3 resimden 3.
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S USB Port Replacement: adım 4, 1 resimden 1.
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S USB Port Replacement, Motherboard: adım 5, 2 resimden 1. Vtech InnoTab 3S USB Port Replacement, Motherboard: adım 5, 2 resimden 2.
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S USB Port Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S USB Port Replacement, USB Port: adım 7, 3 resimden 1. Vtech InnoTab 3S USB Port Replacement, USB Port: adım 7, 3 resimden 2. Vtech InnoTab 3S USB Port Replacement, USB Port: adım 7, 3 resimden 3.
    • The mini USB port is located near the top of the device and is secured by four metal prongs underneath the port.
    • Facing the underside of the USB port, solder the metal prongs securing the USB port to the device.
    • Avoid forceful movements when soldering to prevent damage of device components and avoid personal injury.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
taweewatchulikavit
398 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G2
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,441
