Ana içeriğe geç
Vtech Innotab 3 Button Replacement
Neye ihtiyacın var
  1. Vtech Innotab 3 Button Replacement, Rear Panel: adım 1, 3 resimden 1. Vtech Innotab 3 Button Replacement, Rear Panel: adım 1, 3 resimden 2. Vtech Innotab 3 Button Replacement, Rear Panel: adım 1, 3 resimden 3.
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Button Replacement: adım 2, 1 resimden 1.
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Button Replacement: adım 3, 3 resimden 1. Vtech Innotab 3 Button Replacement: adım 3, 3 resimden 2. Vtech Innotab 3 Button Replacement: adım 3, 3 resimden 3.
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Button Replacement: adım 4, 1 resimden 1.
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Button Replacement, Button Repair: adım 5, 3 resimden 1. Vtech Innotab 3 Button Replacement, Button Repair: adım 5, 3 resimden 2. Vtech Innotab 3 Button Replacement, Button Repair: adım 5, 3 resimden 3.
    • Remove the four 7.6 mm screws using a PH00 screwdriver.
    • Lift the circuit board up to give yourself room to remove the buttons.
  6. Vtech Innotab 3 Button Replacement: adım 6, 3 resimden 1. Vtech Innotab 3 Button Replacement: adım 6, 3 resimden 2. Vtech Innotab 3 Button Replacement: adım 6, 3 resimden 3.
    • Using a nylon or metal spudger, lift up the buttons to remove them from their holding. they should just pop out of place.
    • The buttons are joined together in pairs, be sure not to break them apart during removal.
Sonuç
Zach Diviney
419 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 5-4, Panko Spring 2015 Colorado Springs, Team 5-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S5G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 563
