Ana içeriğe geç
Vtech Kidibeats Drum Set Battery Replacement
Neye ihtiyacın var
  1. Vtech Kidibeats Drum Set Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Battery Replacement: adım 2, 1 resimden 1.
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Battery Replacement: adım 3, 1 resimden 1.
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Battery Replacement: adım 4, 1 resimden 1.
    • Use your fingers to remove each battery from its housing.
    • When inserting the new batteries, remember to match them according to the image displayed on the battery panel.
Sonuç
Aaron Klementowski
820 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-8, Cagle Spring 2016 USF Tampa, Team 2-8, Cagle Spring 2016 üyesi
USFT-CAGLE-S16S2G8
2 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 22
Her zaman: 907
