Ana içeriğe geç
Vtech Move and Crawl Ball Light Up Buttons Replacement
Neye ihtiyacın var
  1. Vtech Move and Crawl Ball Light Up Buttons Replacement, Battery: adım 1, 2 resimden 1. Vtech Move and Crawl Ball Light Up Buttons Replacement, Battery: adım 1, 2 resimden 2.
    • There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
  2. Vtech Move and Crawl Ball Light Up Buttons Replacement: adım 2, 3 resimden 1. Vtech Move and Crawl Ball Light Up Buttons Replacement: adım 2, 3 resimden 2. Vtech Move and Crawl Ball Light Up Buttons Replacement: adım 2, 3 resimden 3.
    • Pry the batteries out with your finger. When you replace them be sure to orient them correctly according to the markings in the slots. Match the plus symbol on the battery to the plus symbol in the slot.
  3. Vtech Move and Crawl Ball Light Up Buttons Replacement, Motor: adım 3, 3 resimden 1. Vtech Move and Crawl Ball Light Up Buttons Replacement, Motor: adım 3, 3 resimden 2. Vtech Move and Crawl Ball Light Up Buttons Replacement, Motor: adım 3, 3 resimden 3.
    • Remove 6 screws in order to pop off the outer shell and reach the inside components.
  4. Vtech Move and Crawl Ball Light Up Buttons Replacement: adım 4, 3 resimden 1. Vtech Move and Crawl Ball Light Up Buttons Replacement: adım 4, 3 resimden 2. Vtech Move and Crawl Ball Light Up Buttons Replacement: adım 4, 3 resimden 3.
    • Remove the motor by lifting it out of the shell, and find the attached wires at both ends: the circuit board and the motor itself. Use the soldering iron to remove the existing attachments by heating the solder joint with the solder iron tip while pulling on the wire.
    • Make sure the motor is aligned over the correct holes during reassembly.
  5. Vtech Move and Crawl Ball Light Up Buttons Replacement, Light Up Buttons: adım 5, 3 resimden 1. Vtech Move and Crawl Ball Light Up Buttons Replacement, Light Up Buttons: adım 5, 3 resimden 2. Vtech Move and Crawl Ball Light Up Buttons Replacement, Light Up Buttons: adım 5, 3 resimden 3.
    • When the white cover and the ball motor have been removed, the 6 push buttons will be easily accessible. 3 of the buttons can be removed from their slots by gently pulling up on each. The other 3 buttons are located lower in the unit and are held in by 1 phillips screw each.
    • When reassembling ensure that the button is in the inner slot circled in the picture with the button, and shown by the arrows with the button removed.
  6. Vtech Move and Crawl Ball Light Up Buttons Replacement: adım 6, 1 resimden 1.
    • The button which is being replaced needs to be disconnected from the motherboard using the soldering iron. The replacement should be soldered into the same place.
Sonuç
Steven Ivanov
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Sullivan Fall 2015 USF Tampa, Team 2-1, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G1
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 792
