Ana içeriğe geç
Vtech Move and Crawl Ball Power Switch Replacement
Neye ihtiyacın var
  1. Vtech Move and Crawl Ball Power Switch Replacement, Battery: adım 1, 2 resimden 1. Vtech Move and Crawl Ball Power Switch Replacement, Battery: adım 1, 2 resimden 2.
    • There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
    FixBot'a Sor
    Yorum Ekle
  2. Vtech Move and Crawl Ball Power Switch Replacement: adım 2, 3 resimden 1. Vtech Move and Crawl Ball Power Switch Replacement: adım 2, 3 resimden 2. Vtech Move and Crawl Ball Power Switch Replacement: adım 2, 3 resimden 3.
    • Pry the batteries out with your finger. When you replace them be sure to orient them correctly according to the markings in the slots. Match the plus symbol on the battery to the plus symbol in the slot.
    FixBot'a Sor
    Yorum Ekle
  3. Vtech Move and Crawl Ball Power Switch Replacement, Motor: adım 3, 3 resimden 1. Vtech Move and Crawl Ball Power Switch Replacement, Motor: adım 3, 3 resimden 2. Vtech Move and Crawl Ball Power Switch Replacement, Motor: adım 3, 3 resimden 3.
    • Remove 6 screws in order to pop off the outer shell and reach the inside components.
    FixBot'a Sor
    Yorum Ekle
  4. Vtech Move and Crawl Ball Power Switch Replacement: adım 4, 3 resimden 1. Vtech Move and Crawl Ball Power Switch Replacement: adım 4, 3 resimden 2. Vtech Move and Crawl Ball Power Switch Replacement: adım 4, 3 resimden 3.
    • Remove the motor by lifting it out of the shell, and find the attached wires at both ends: the circuit board and the motor itself. Use the soldering iron to remove the existing attachments by heating the solder joint with the solder iron tip while pulling on the wire.
    • Make sure the motor is aligned over the correct holes during reassembly.
    FixBot'a Sor
    Yorum Ekle
  5. Vtech Move and Crawl Ball Power Switch Replacement, Power Switch: adım 5, 1 resimden 1.
    • Unscrew the two screws to the power switch located beside the circuit board
    FixBot'a Sor
    Yorum Ekle
  6. Vtech Move and Crawl Ball Power Switch Replacement: adım 6, 3 resimden 1. Vtech Move and Crawl Ball Power Switch Replacement: adım 6, 3 resimden 2. Vtech Move and Crawl Ball Power Switch Replacement: adım 6, 3 resimden 3.
    • Remove the existing attachments at both ends of the wires with the soldering iron. Heat the solder joint with the solder iron tip and pull the wire.
    FixBot'a Sor
    Yorum Ekle
Sonuç
William Jones
222 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Sullivan Fall 2015 USF Tampa, Team 2-1, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G1
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 1,135
