Ana içeriğe geç
Vtech Touch and Swipe Baby Phone Power Switch Replacement
Neye ihtiyacın var
  1. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: adım 1, 2 resimden 1. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: adım 1, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: adım 2, 3 resimden 1. Vtech Touch and Swipe Baby Phone Power Switch Replacement: adım 2, 3 resimden 2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: adım 2, 3 resimden 3.
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Vtech Touch and Swipe Baby Phone Power Switch Replacement: adım 3, 3 resimden 1. Vtech Touch and Swipe Baby Phone Power Switch Replacement: adım 3, 3 resimden 2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: adım 3, 3 resimden 3.
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: adım 4, 2 resimden 1. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: adım 4, 2 resimden 2.
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Vtech Touch and Swipe Baby Phone Power Switch Replacement: adım 5, 3 resimden 1. Vtech Touch and Swipe Baby Phone Power Switch Replacement: adım 5, 3 resimden 2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: adım 5, 3 resimden 3.
    • Lift directly up to remove the switch and lay the wire down to the side.
    • Once the switch has been taken out you can remove the switch's casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
tellocordova
342 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G4
3 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
Good work.
I have done it the same way,
the wire at the switch was bad soldered,
but it was easy to repair it and i soldered it new.
Nice.
Schwarzstein - Yanıt
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
shakinsher - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 844
