Ana içeriğe geç
VuPoint DC-ST210-VP LCD Screen Replacement
Neye ihtiyacın var
  1. VuPoint DC-ST210-VP LCD Screen Replacement, Turn Off/Remove Batteries: adım 1, 1 resimden 1.
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: adım 2, 3 resimden 1. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: adım 2, 3 resimden 2. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: adım 2, 3 resimden 3.
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: adım 3, 2 resimden 1. VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: adım 3, 2 resimden 2.
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Circuit Board Screws: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Using a Phillips #00 screwdriver, remove the 5 (3.5mm in length) screws shown to the left.
    • Remember to place small screws on magnetic mat or in a container.
  5. VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: adım 5, 3 resimden 1. VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: adım 5, 3 resimden 2. VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: adım 5, 3 resimden 3.
    • Using a pry tool or fingernail, gently pry the circuit board from the base.
    • Gently lift the lower right hand corner of the circuit board, separating it from the base.
  6. VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: adım 6, 3 resimden 1. VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: adım 6, 3 resimden 2. VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: adım 6, 3 resimden 3.
    • Locate LCD and gently bend it back to reveal ribbon cable connector.
    • Using small screw driver or tweezers gently slide the edges of the ribbon lock towards the direction of the cable.
    • Once the lock is opened, use tweezers to slide the ribbon cable from the connector.
    • Replace LCD as needed and repeat steps in reverse to reassemble.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lincoln Thompson
32 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G15
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 393
