Ana içeriğe geç
Vulcan Venture II VNB14002IE I/O Board Replacement
Neye ihtiyacın var
  1. Vulcan Venture II VNB14002IE I/O Board Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE I/O Board Replacement: adım 2, 1 resimden 1.
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE I/O Board Replacement, I/O Board: adım 3, 1 resimden 1.
    • Locate the IO board on the back panel.
  4. Vulcan Venture II VNB14002IE I/O Board Replacement: adım 4, 2 resimden 1. Vulcan Venture II VNB14002IE I/O Board Replacement: adım 4, 2 resimden 2.
    • Locate the ribbon connector on the IO board, and lift the black bar closest the the ribbon.
    • Pull the ribbon cable away from the connector, releasing it.
  5. Vulcan Venture II VNB14002IE I/O Board Replacement: adım 5, 2 resimden 1. Vulcan Venture II VNB14002IE I/O Board Replacement: adım 5, 2 resimden 2.
    • Locate the screws on the IO panel, and use the J00+ bit to unscrew them.
  6. Vulcan Venture II VNB14002IE I/O Board Replacement: adım 6, 1 resimden 1.
    • The IO Board is now safe to remove from the computer.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 534
