Ana içeriğe geç
Vulcan Venture II VNB14002IE Motherboard Replacement
Neye ihtiyacın var
  1. Vulcan Venture II VNB14002IE Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE Motherboard Replacement: adım 2, 1 resimden 1.
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Disconnect the 4 ribbon cables connected to the motherboard by carefully lifting up the black bar attached to the housing. Slowly slide the cable out once released.
    • Disconnect the wire connected to the motherboard.
    • Disconnect the battery by gently pulling out the cable connected to the board.
  4. Vulcan Venture II VNB14002IE Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the screws located in the corners of the board using a J00 screwdriver.
  5. Vulcan Venture II VNB14002IE Motherboard Replacement: adım 5, 1 resimden 1.
    • Gently lift the board out of the housing without any cables still connected to the board.
    • Picture shows the housing of the motherboard after the motherboard has been removed.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 468
