Giriş
Many small tires use inner tubes which are tubes that hold the air pressure for the tire. It is common for inner tubes to leak air pressure or get punctured. Replacing the inner tube is easy. The process requires you to remove the tire from the rim, swap the old inner tube with a new inner tube, and then reassemble the tire to inflate it.
Neye ihtiyacın var
Gently pull out the valve stem so that it faces you. You may have to flip the tire to make it face you.
Take the bottom rim half and partially push it into the bottom of the tire. The bottom rim half contains the nuts for the bolts.
Align the valve stem cutout in the bottom rim half with the valve stem.
Push the bottom rim half into the tire until the valve stem and rim touch.
The tire is now ready to be attached to its axle.
Bir başkası bu kılavuzu tamamladı.
