Ana içeriğe geç
WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Knob Replacement
Neye ihtiyacın var
  1. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Knob Replacement, Pressure Regulator Knob: adım 1, 1 resimden 1.
    • Using a 2mm Allen wrench, remove the Allen screw located on the pressure regulator knob on the back of the brad nailer.
  2. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Knob Replacement: adım 2, 1 resimden 1.
    • Remove the knob from the gun and replace the knob.
    • Be aware of the rubber spacer that will come off with the knob; when you replace the knob put the spacer back in the middle around the screw hole.
Sonuç
Ousman Jammeh
507 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 232
