Ana içeriğe geç
WLAN / Bluetooth Card Replacement
Neye ihtiyacın var
  1. WLAN / Bluetooth Card Replacement, Battery: adım 1, 3 resimden 1. WLAN / Bluetooth Card Replacement, Battery: adım 1, 3 resimden 2. WLAN / Bluetooth Card Replacement, Battery: adım 1, 3 resimden 3.
    • Unlock the battery latch on the right.
    • Unlock the battery lock on the left.
    • Remove the battery pack from its slot.
  2. WLAN / Bluetooth Card Replacement, Access to Components 2: adım 2, 3 resimden 1. WLAN / Bluetooth Card Replacement, Access to Components 2: adım 2, 3 resimden 2. WLAN / Bluetooth Card Replacement, Access to Components 2: adım 2, 3 resimden 3.
    • Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
    • Check the marks indicating the direction in which the cover must be removed.
    • Remove the bottom cover by removing it in the direction of the markers.
  3. WLAN / Bluetooth Card Replacement: adım 3, 1 resimden 1.
    • Then appear the other components of the Laptop.
  4. WLAN / Bluetooth Card Replacement, WLAN / Bluetooth card: adım 4, 3 resimden 1. WLAN / Bluetooth Card Replacement, WLAN / Bluetooth card: adım 4, 3 resimden 2. WLAN / Bluetooth Card Replacement, WLAN / Bluetooth card: adım 4, 3 resimden 3.
    • Here is the WLAN Chipset / Bluetooth
    • Gently unplug the MAIN and AUX antennas.
    • Unscrew the fixing screw with Philips # 0 screwdriver.
  5. WLAN / Bluetooth Card Replacement: adım 5, 2 resimden 1. WLAN / Bluetooth Card Replacement: adım 5, 2 resimden 2.
    • Slightly lift the chipset and remove it from the mSATA connector.
    • Here is the chipset outside of its location.
Sonuç
To reassemble your device follow the following instructions in reverse order
Bu çevirmenlere özel teşekkürler:
fr en
100%
irlanda dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.538 İtibar
283 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 572
