Ana içeriğe geç
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
Neye ihtiyacın var
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: adım 1, 2 resimden 1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
    FixBot'a Sor
    Yorum Ekle
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: adım 2, 1 resimden 1.
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
    FixBot'a Sor
    Yorum Ekle
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: adım 3, 2 resimden 1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: adım 3, 2 resimden 2.
    • Remove the belt guard.
    FixBot'a Sor
    Yorum Ekle
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: adım 4, 3 resimden 1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: adım 4, 3 resimden 2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: adım 4, 3 resimden 3.
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
    FixBot'a Sor
    Yorum Ekle
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: adım 5, 1 resimden 1.
    • Loop the replacement belt onto the small pulley.
    FixBot'a Sor
    Yorum Ekle
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: adım 6, 3 resimden 1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: adım 6, 3 resimden 2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: adım 6, 3 resimden 3.
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Arthur Shi
343.925 İtibar
915 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.359 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 3,949
