Ana içeriğe geç
Wacom Intuos4 Express Keys Replacement
Neye ihtiyacın var
  1. Wacom Intuos4 Express Keys Replacement, Casing: adım 1, 3 resimden 1. Wacom Intuos4 Express Keys Replacement, Casing: adım 1, 3 resimden 2. Wacom Intuos4 Express Keys Replacement, Casing: adım 1, 3 resimden 3.
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Express Keys Replacement: adım 2, 2 resimden 1. Wacom Intuos4 Express Keys Replacement: adım 2, 2 resimden 2.
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Express Keys Replacement, Express Keys: adım 3, 3 resimden 1. Wacom Intuos4 Express Keys Replacement, Express Keys: adım 3, 3 resimden 2. Wacom Intuos4 Express Keys Replacement, Express Keys: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift yellow tape covering the flat wires with a pair of tweezers.
    • Lift the black plastic clip holding the flat wire to the connector.
    • This should be done with a plastic tool to avoid damaging the contacts.
    • Pull on the white plastic tab to disconnect the flat wire.
    • Do this for the left and right express key chips.
  4. Wacom Intuos4 Express Keys Replacement: adım 4, 1 resimden 1.
    • Pull the black plastic clip away from the flat wire connector, and pull the flat wire out.
    • It may be easier to pull with a tool on one side, and with your hand on the other at the same time.
  5. Wacom Intuos4 Express Keys Replacement: adım 5, 1 resimden 1.
    • Use a #1 Phillips head screwdriver to unscrew the four 5mm screws on the express key board you want to replace.
  6. Wacom Intuos4 Express Keys Replacement: adım 6, 2 resimden 1. Wacom Intuos4 Express Keys Replacement: adım 6, 2 resimden 2.
    • Lift the board and rubber buttons up from the case.
    • Separate the rubber buttons from the board.
Sonuç
Aidan Sullivan
293 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Botvin Fall 2022 UMass Dartmouth, Team 3-6, Botvin Fall 2022 üyesi
UMASSD-BOTVIN-F22S3G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 239
