Ana içeriğe geç
Wacom Intuos4 Foam Safety Pad Replacement
Neye ihtiyacın var
  1. Wacom Intuos4 Foam Safety Pad Replacement, Casing: adım 1, 3 resimden 1. Wacom Intuos4 Foam Safety Pad Replacement, Casing: adım 1, 3 resimden 2. Wacom Intuos4 Foam Safety Pad Replacement, Casing: adım 1, 3 resimden 3.
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Foam Safety Pad Replacement: adım 2, 2 resimden 1. Wacom Intuos4 Foam Safety Pad Replacement: adım 2, 2 resimden 2.
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Foam Safety Pad Replacement, Foam Safety Pad: adım 3, 1 resimden 1.
    • Use a spudger to safely remove the white and sliver pad without applying enough pressure to scratch the motherboard.
Sonuç
Aidan Sullivan
293 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Botvin Fall 2022 UMass Dartmouth, Team 3-6, Botvin Fall 2022 üyesi
UMASSD-BOTVIN-F22S3G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 110
