Ana içeriğe geç
Wahl Chrome Pro Motor Replacement
Neye ihtiyacın var
  1. Wahl Chrome Pro Motor Replacement, Case: adım 1, 1 resimden 1.
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Motor Replacement: adım 2, 1 resimden 1.
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Motor Replacement: adım 3, 1 resimden 1.
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Motor Replacement: adım 4, 1 resimden 1.
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Motor Replacement: adım 5, 1 resimden 1.
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Motor Replacement: adım 6, 1 resimden 1.
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Motor Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Motor Replacement: adım 8, 1 resimden 1.
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Motor Replacement, Motor: adım 9, 1 resimden 1.
    • Lift power cord tab (black wire) from slot on motor base.
  10. Wahl Chrome Pro Motor Replacement: adım 10, 1 resimden 1.
    • Lift switch tab (teal wire) from slot on motor base.
  11. Wahl Chrome Pro Motor Replacement: adım 11, 1 resimden 1.
    • Remove two 23.0 mm JIS #1 screws attaching motor base to device body.
  12. Wahl Chrome Pro Motor Replacement: adım 12, 1 resimden 1.
    • Lift motor base straight up from device body to remove.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ashley Dale
312 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S7-G3, Baechle Fall 2017 IUPUI, Team S7-G3, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S7G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,418
