Ana içeriğe geç
Wahl Hair Clippers Model ST115VAC Power Cord Replacement
Neye ihtiyacın var
  1. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement, Power Cord: adım 1, 1 resimden 1.
    • Unscrew the three 12mm black JIS screw found on the red side of the the device with a JIS #1 driver.
  2. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: adım 2, 1 resimden 1.
    • Grab the red cover by the side and lift off the top piece.
  3. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: adım 3, 1 resimden 1.
    • Unscrew the 5.556mm screw with a JIS #0 screwdriver. (Black Screw located at power switch)
  4. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Spudger
    $2.99
    Satın Al
    • Insert the metal spudger between the wire connector and the device connector. The spudger should disengage a tension-like lock between both connectors, and once disengaged gently pry out the cord connection.
    • (Note-dependent on varying user conditions, the connection may be harder to remove and may involve more force or a gentle rocking to separate connection.)
    • When working with electronics, make to use an ESD safe tool, to avoid shock. Try using the black nylon spudger instead.
  5. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: adım 5, 1 resimden 1.
    • Remove the cord from the fixed position.
Sonuç
To reassemble your device, follow these instructions in reverse order. When installing new cord, make sure black wire is underneath the white wire.
3 farklı kişi bu kılavuzu tamamladı.
Julio Alvarado
131 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 10-4, Remmell Spring 2017 USF Tampa, Team 10-4, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S10G4
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 30
Her zaman: 3,016
