Ana içeriğe geç
Wahl Lithium Ion 5537C Blade Replacement
Neye ihtiyacın var
  1. Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: adım 1, 2 resimden 1. Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: adım 1, 2 resimden 2.
    • Take out the batteries by pulling off the cover from the back and once done put the cover back on.
  2. Wahl Lithium Ion 5537C Blade Replacement: adım 2, 3 resimden 1. Wahl Lithium Ion 5537C Blade Replacement: adım 2, 3 resimden 2. Wahl Lithium Ion 5537C Blade Replacement: adım 2, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the two screws on the blade and place them in the container.
    • Detach the blade from the body of the shaver and also remove the blade supporting mounts.
  3. Wahl Lithium Ion 5537C Blade Replacement: adım 3, 3 resimden 1. Wahl Lithium Ion 5537C Blade Replacement: adım 3, 3 resimden 2. Wahl Lithium Ion 5537C Blade Replacement: adım 3, 3 resimden 3.
    • Grab the replacement new blade and before mounting the support mount clean it with the cleaning brush to remove any dirt.
    • Place the supporting mount back to the new blade making sure it is properly attached.
  4. Wahl Lithium Ion 5537C Blade Replacement: adım 4, 3 resimden 1. Wahl Lithium Ion 5537C Blade Replacement: adım 4, 3 resimden 2. Wahl Lithium Ion 5537C Blade Replacement: adım 4, 3 resimden 3.
    • Place the blade with mount attached to the trimmer such that the screw holes are visible through
    • Grab on the blade hard and torque both screws one by one.
    • Check if the blade is attached tightly to the trimmer.
    • Insert the batteries inside the trimmer and start using!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Osman Saeed
109 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 17
Son 30 gün: 72
Her zaman: 1,535
