Ana içeriğe geç
Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement
Neye ihtiyacın var
  1. Wahl Lithium Ion Trimmer  Lithium Ion Battery Replacement, Disassembling of Wahl Lithium Ion Trimmer: adım 1, 2 resimden 1. Wahl Lithium Ion Trimmer  Lithium Ion Battery Replacement, Disassembling of Wahl Lithium Ion Trimmer: adım 1, 2 resimden 2.
    • Begin by removing the rubber grip along the handle.
  2. Wahl Lithium Ion Trimmer  Lithium Ion Battery Replacement: adım 2, 1 resimden 1.
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Wahl Lithium Ion Trimmer  Lithium Ion Battery Replacement: adım 3, 2 resimden 1. Wahl Lithium Ion Trimmer  Lithium Ion Battery Replacement: adım 3, 2 resimden 2.
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
  4. Wahl Lithium Ion Trimmer  Lithium Ion Battery Replacement, Lithium Ion Battery Replacement: adım 4, 1 resimden 1.
    • Remove the chip set, motor and battery from the plastic body. This photo shows the motor and wires connecting it to the battery.
  5. Wahl Lithium Ion Trimmer  Lithium Ion Battery Replacement: adım 5, 1 resimden 1.
    • Remove the white plastic cover over the chip set allowing the battery to be taken off.
  6. Wahl Lithium Ion Trimmer  Lithium Ion Battery Replacement: adım 6, 1 resimden 1.
    • Remove the Lithium Ion Battery and replace it with the new one that you purchased.
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
nathan
1.410 İtibar
6 adet Kılavuz yazıldı
18 Yorum
Great guide but I made the mistake of buying just a standard 3.7v 750mAh battery to try and fit into the trimmer. The battery in the trimmer has metal terminals "stamped" to each end, so the terminals can't be unsoldered from the battery. I was hoping to just unsolder the existing battery and then solder in the new one but no such luck. New trimmer for me now lol
Dean Miller - Yanıt
DM, I used a dremel tool with a thin grinding wheel to cut off the metal terminals just below the stamp point. After cutting off the metal terminals below the stamp point, approximately 1/4" inch of the terminals still remained which was just enough to connect the new battery to the remaining metal terminals with a small dab of solder. Little bit more work than I was anticipating but the trimmer works like new again. Found the 3.7v 750mAh battery at onlybatteries.com for $5 plus about $5.94 for shipping. Hope this helps for you DIYers!!
Dean Lamborn, 10/25/2015
Dean Lamborn - Yanıt
Is it an 18650 size?
David Drasser -
Nope, it is a AA size 14500 lithium battery.
Adam Drews -
To Nathan, DM and DL, I was with Nathan until I read about soldering a dremel (which i I own) and cutting off the metal terminals below the stamp point. Can any of you fine 'fixers' show pictures along with the soldering, dremel, cutting, terminals description? I want my Chromado to work like new too! Thanks in advance, Ka
Ka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 27
Son 30 gün: 261
Her zaman: 72,628
