Ana içeriğe geç
Wahl Lithium Ion Trimmer Slide switch Replacement
  1. Wahl Lithium Ion Trimmer  Slide switch Replacement, Slide switch: adım 1, 1 resimden 1.
    • Start at the last step of the disassembly guide.
  2. Wahl Lithium Ion Trimmer  Slide switch Replacement: adım 2, 1 resimden 1.
    • remove the inside on the razor which includes the chip set, battery, motor and switch.
  3. Wahl Lithium Ion Trimmer  Slide switch Replacement: adım 3, 1 resimden 1.
    • focus on the chip set and the white piece on top. The white piece is the switch that turns the razor on and off.
  4. Wahl Lithium Ion Trimmer  Slide switch Replacement: adım 4, 1 resimden 1.
    • Remove the white piece. Be careful doing so because the chip set is delicate and breaking that would result in replacing that as well.
  5. Wahl Lithium Ion Trimmer  Slide switch Replacement: adım 5, 1 resimden 1.
    • Upon removing the switch, exchange the broken part with the new one that you bought and replace it. Once installed put the razor back together and now you will be able to turn the razor on and off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
nathan
1.422 İtibar
6 adet Kılavuz yazıldı
1Rehber Yorum
Where can you source this part from?
John - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 34
Her zaman: 3,440
