Ana içeriğe geç
Wahl Lithium Ion Trimmer Metal Razor Arms Replacement
Neye ihtiyacın var
  1. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement, Metal Razor Arms: adım 1, 1 resimden 1.
    • Examine the razor to identify any broken or jammed blades, if any the whole set must be changed.
  2. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: adım 2, 1 resimden 1.
    • Unscrew the two Phillips screws with a Phillips #0 screwdriver.
    • Set those two screws aside for reassembly.
  3. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: adım 3, 1 resimden 1.
    • Apply pressure to the back side of the blades while pushing outward to completely remove the blade head.
  4. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: adım 4, 3 resimden 1. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: adım 4, 3 resimden 2. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: adım 4, 3 resimden 3.
    • Put the Phillips #0 screwdriver in the opening and pry out the metal clip.
    • Set aside the metal clip for reassembly
  5. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: adım 5, 1 resimden 1.
    • Separate the Wahl Lithium Ion Trimmer head into its four components.
    • Remove the damaged blade and replace it with a new one.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
nathan
1.422 İtibar
6 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where can I get replacement arms?
Sam - Yanıt
Where can one obtain a new spring???
tinkrmann - Yanıt
The spring popped out of the head, but your pictures are too blurry to see how it goes back together.
Mark Wilson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 19,645
