Ana içeriğe geç
Wahl Professional Designer Motor Replacement
Neye ihtiyacın var
  1. Wahl Professional Designer Motor Replacement, Motor: adım 1, 2 resimden 1. Wahl Professional Designer Motor Replacement, Motor: adım 1, 2 resimden 2.
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Motor Replacement: adım 2, 3 resimden 1. Wahl Professional Designer Motor Replacement: adım 2, 3 resimden 2. Wahl Professional Designer Motor Replacement: adım 2, 3 resimden 3.
    • Remove the wires connected to the motor by firmly grasping both sides of a wire and wiggling until it is released.
  3. Wahl Professional Designer Motor Replacement: adım 3, 3 resimden 1. Wahl Professional Designer Motor Replacement: adım 3, 3 resimden 2. Wahl Professional Designer Motor Replacement: adım 3, 3 resimden 3.
    • Unscrew the two 20.5 mm Phillip head screw located on the motor using a Phillip's #1 screwdriver.
  4. Wahl Professional Designer Motor Replacement: adım 4, 2 resimden 1. Wahl Professional Designer Motor Replacement: adım 4, 2 resimden 2.
    • Gently remove the motor from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sophia Swearengin
718 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G5, Boczar Fall 2017 USF Tampa, Team S14-G5, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G5
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 1,194
