Ana içeriğe geç
Wahl Professional Designer Power Cord Replacement
Neye ihtiyacın var
  1. Wahl Professional Designer Power Cord Replacement, Power Cord: adım 1, 2 resimden 1. Wahl Professional Designer Power Cord Replacement, Power Cord: adım 1, 2 resimden 2.
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Power Cord Replacement: adım 2, 3 resimden 1. Wahl Professional Designer Power Cord Replacement: adım 2, 3 resimden 2. Wahl Professional Designer Power Cord Replacement: adım 2, 3 resimden 3.
    • Remove the cover from the device.
  3. Wahl Professional Designer Power Cord Replacement: adım 3, 3 resimden 1. Wahl Professional Designer Power Cord Replacement: adım 3, 3 resimden 2. Wahl Professional Designer Power Cord Replacement: adım 3, 3 resimden 3.
    • Unscrew the black 5.556 mm Phillip head screw on the power switch, closest to the power cord with a Phillips #0 Screwdriver.
  4. Wahl Professional Designer Power Cord Replacement: adım 4, 2 resimden 1. Wahl Professional Designer Power Cord Replacement: adım 4, 2 resimden 2.
    • Gently remove the black wire connected to the black screw.
  5. Wahl Professional Designer Power Cord Replacement: adım 5, 3 resimden 1. Wahl Professional Designer Power Cord Replacement: adım 5, 3 resimden 2. Wahl Professional Designer Power Cord Replacement: adım 5, 3 resimden 3.
    • Remove the white wire connected to the power cord and the motor by grabbing the white wire firmly on both sides near the motor mounting and wiggling until release.
  6. Wahl Professional Designer Power Cord Replacement: adım 6, 2 resimden 1. Wahl Professional Designer Power Cord Replacement: adım 6, 2 resimden 2.
    • Remove the power cord from its mount at the bottom of the device.
Sonuç
Sophia Swearengin
790 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G5, Boczar Fall 2017 USF Tampa, Team S14-G5, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G5
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 507
