Ana içeriğe geç
Wahl Professional Designer Power Switch Replacement
Neye ihtiyacın var
  1. Wahl Professional Designer Power Switch Replacement, Power Switch: adım 1, 2 resimden 1. Wahl Professional Designer Power Switch Replacement, Power Switch: adım 1, 2 resimden 2.
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Power Switch Replacement: adım 2, 2 resimden 1. Wahl Professional Designer Power Switch Replacement: adım 2, 2 resimden 2.
    • Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
  3. Wahl Professional Designer Power Switch Replacement: adım 3, 3 resimden 1. Wahl Professional Designer Power Switch Replacement: adım 3, 3 resimden 2. Wahl Professional Designer Power Switch Replacement: adım 3, 3 resimden 3.
    • Shimmy the power switch off the mount until it is completely removed.
Sonuç
Sophia Swearengin
718 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G5, Boczar Fall 2017 USF Tampa, Team S14-G5, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G5
2 Üyeler
Bir Yorum
Hello Mrs/ms Swearengin, I’m disassembled my Wahl desingner I’m unable to make the power switch stiff . It’s very loose I can’t recall which screw goes in between two black 5.556 mm Phillip head screw or if it needs a screw at all
Carlos Olvera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 583
