Ana içeriğe geç
Wall Outlet Cover Replacement
Neye ihtiyacın var
    1. Wall Outlet Cover Replacement, Wall Outlet Cover: adım 1, 3 resimden 1. Wall Outlet Cover Replacement, Wall Outlet Cover: adım 1, 3 resimden 2. Wall Outlet Cover Replacement, Wall Outlet Cover: adım 1, 3 resimden 3.
      • Remove any hazardous pieces from previous cover.
      • Be sure to remove the two flathead screws to remove any debris, rather than trying to pull off the sharp pieces.
      FixBot'a Sor
      Yorum Ekle
    2. Wall Outlet Cover Replacement: adım 2, 3 resimden 1. Wall Outlet Cover Replacement: adım 2, 3 resimden 2. Wall Outlet Cover Replacement: adım 2, 3 resimden 3.
      • Insert any cable or cables that may be hanging out inside of the wall hole.
      • Making a loop in the cable might be helpful to push it inside the wall.
      FixBot'a Sor
      Yorum Ekle
    3. Wall Outlet Cover Replacement: adım 3, 1 resimden 1.
      • Insert two screws into the holes of the new wall cover.
      FixBot'a Sor
      Yorum Ekle
    4. Wall Outlet Cover Replacement: adım 4, 3 resimden 1. Wall Outlet Cover Replacement: adım 4, 3 resimden 2. Wall Outlet Cover Replacement: adım 4, 3 resimden 3.
      • Line up the screws in the plate with the screw holes in the wall.
      • Tighten the screws slightly with your hands to ensure that both screws have found the proper holes.
      • Once the screws have been tightened enough to stay in the holes, they should hold the outlet cover in place.
      FixBot'a Sor
      Yorum Ekle
    5. Wall Outlet Cover Replacement: adım 5, 3 resimden 1. Wall Outlet Cover Replacement: adım 5, 3 resimden 2. Wall Outlet Cover Replacement: adım 5, 3 resimden 3.
      • Tighten the two screws with a flathead screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Wall Outlet Cover Replacement: adım 6, 3 resimden 1. Wall Outlet Cover Replacement: adım 6, 3 resimden 2. Wall Outlet Cover Replacement: adım 6, 3 resimden 3.
      • Double check that the wall cover plate does not have a gap, and it is completely attached to the wall.
      • If any gap is detected, push the plate to the wall and continue to tighten the screws until the gap completely closes.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Leydi Navarrete
197 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 32
Son 30 gün: 119
Her zaman: 3,383
