Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Insert any cable or cables that may be hanging out inside of the wall hole.
Insert two screws into the holes of the new wall cover.
Line up the screws in the plate with the screw holes in the wall.
Tighten the screws slightly with your hands to ensure that both screws have found the proper holes.
Double check that the wall cover plate does not have a gap, and it is completely attached to the wall.
If any gap is detected, push the plate to the wall and continue to tighten the screws until the gap completely closes.
