Ana içeriğe geç
Waring 51BL29 Drive Coupling Replacement
Neye ihtiyacın var
    1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: adım 1, 2 resimden 1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: adım 1, 2 resimden 2.
      • Turn the blender on its side so the bottom panel is facing you.
      • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
      • Unscrew the 3 screws in the rubber holes.
      FixBot'a Sor
      Yorum Ekle
    2. Waring 51BL29 Drive Coupling Replacement: adım 2, 1 resimden 1.
      • Remove the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    1. Waring 51BL29 Drive Coupling Replacement, Drive Coupling: adım 3, 1 resimden 1.
      • Place the screwdriver in the head of the middle flat-head screw.
      FixBot'a Sor
      Yorum Ekle
    2. Waring 51BL29 Drive Coupling Replacement: adım 4, 1 resimden 1.
      • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
      • This screw may be reverse-threaded.
      FixBot'a Sor
      Yorum Ekle
    3. Waring 51BL29 Drive Coupling Replacement: adım 5, 1 resimden 1.
      • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Dean Becker
485 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G4, Banghart Spring 2017 Cal Poly, Team S15-G4, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S15G4
4 Üyeler
20 adet Kılavuz yazıldı
1Rehber Yorum
Do you happen to know where I can purchase this replacement part?
Jessica Dye - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 81
Her zaman: 9,131
