Ana içeriğe geç
Waring 51BL29 Switch Replacement
Neye ihtiyacın var
  1. Waring 51BL29 Switch Replacement, Bottom Panel: adım 1, 2 resimden 1. Waring 51BL29 Switch Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Switch Replacement: adım 2, 1 resimden 1.
    • Remove the bottom panel.
  3. Waring 51BL29 Switch Replacement, Drive Coupling: adım 3, 1 resimden 1.
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Switch Replacement: adım 4, 1 resimden 1.
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Switch Replacement: adım 5, 1 resimden 1.
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Switch Replacement, Motor: adım 6, 2 resimden 1. Waring 51BL29 Switch Replacement, Motor: adım 6, 2 resimden 2.
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Switch Replacement: adım 7, 1 resimden 1.
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Switch Replacement: adım 8, 3 resimden 1. Waring 51BL29 Switch Replacement: adım 8, 3 resimden 2. Waring 51BL29 Switch Replacement: adım 8, 3 resimden 3.
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
  9. Waring 51BL29 Switch Replacement, Switch: adım 9, 1 resimden 1.
    • Once you have the motor and switch by themselves it should look like this.
  10. Waring 51BL29 Switch Replacement: adım 10, 2 resimden 1. Waring 51BL29 Switch Replacement: adım 10, 2 resimden 2.
    • Separate the zip-tie holding the wires to the motor.
  11. Waring 51BL29 Switch Replacement: adım 11, 1 resimden 1.
    • Now the switch is separated from the motor and blender frame.
Sonuç
Dean Becker
470 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G4, Banghart Spring 2017 Cal Poly, Team S15-G4, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S15G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 687
