Ana içeriğe geç
Waring Pro SB30 Hot Plate Replacement
Neye ihtiyacın var
    1. Waring Pro SB30 Hot Plate Replacement, Back Panel: adım 1, 1 resimden 1.
      • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
      • The screws in the rubber legs of the burner do not need to be removed.
      • If the back panel has never been opened before, the screws may be more difficult to unscrew.
      FixBot'a Sor
      Yorum Ekle
    2. Waring Pro SB30 Hot Plate Replacement: adım 2, 2 resimden 1. Waring Pro SB30 Hot Plate Replacement: adım 2, 2 resimden 2.
      • Using a wrench, remove the bolt from the center of the back panel.
      FixBot'a Sor
      Yorum Ekle
    3. Waring Pro SB30 Hot Plate Replacement: adım 3, 1 resimden 1.
      • The back panel can now be easily lifted off.
      FixBot'a Sor
      Yorum Ekle
    1. Waring Pro SB30 Hot Plate Replacement, Hot Plate: adım 4, 2 resimden 1. Waring Pro SB30 Hot Plate Replacement, Hot Plate: adım 4, 2 resimden 2.
      • Remove screws #1 Phillips screwdriver bit.
      • The interior edges of the metal frame are sharp and can cause minor cuts.
      • 3 screws on the perimeter of the circle
      • 1 screw in the circle
      • 2 screws on the eletrical stands with wires
      FixBot'a Sor
      Yorum Ekle
    2. Waring Pro SB30 Hot Plate Replacement: adım 5, 2 resimden 1. Waring Pro SB30 Hot Plate Replacement: adım 5, 2 resimden 2.
      • Remove rod from the center of the plate with a wrench.
      FixBot'a Sor
      Yorum Ekle
    3. Waring Pro SB30 Hot Plate Replacement: adım 6, 2 resimden 1. Waring Pro SB30 Hot Plate Replacement: adım 6, 2 resimden 2.
      • Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sun Fai Lau
588 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-7, Brown Fall 2014 USF Tampa, Team 10-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G7
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 2,634
