Ana içeriğe geç
Waring Pro SB30 Hot Plate Replacement
Neye ihtiyacın var
  1. Waring Pro SB30 Hot Plate Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Hot Plate Replacement: adım 2, 2 resimden 1. Waring Pro SB30 Hot Plate Replacement: adım 2, 2 resimden 2.
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Hot Plate Replacement: adım 3, 1 resimden 1.
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Hot Plate Replacement, Hot Plate: adım 4, 2 resimden 1. Waring Pro SB30 Hot Plate Replacement, Hot Plate: adım 4, 2 resimden 2.
    • Remove screws #1 Phillips screwdriver bit.
    • The interior edges of the metal frame are sharp and can cause minor cuts.
    • 3 screws on the perimeter of the circle
    • 1 screw in the circle
    • 2 screws on the eletrical stands with wires
  5. Waring Pro SB30 Hot Plate Replacement: adım 5, 2 resimden 1. Waring Pro SB30 Hot Plate Replacement: adım 5, 2 resimden 2.
    • Remove rod from the center of the plate with a wrench.
  6. Waring Pro SB30 Hot Plate Replacement: adım 6, 2 resimden 1. Waring Pro SB30 Hot Plate Replacement: adım 6, 2 resimden 2.
    • Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sun Fai Lau
588 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-7, Brown Fall 2014 USF Tampa, Team 10-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G7
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 29
Her zaman: 1,957
