Ana içeriğe geç
Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement
Neye ihtiyacın var
  1. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: adım 2, 2 resimden 1. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: adım 2, 2 resimden 2.
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: adım 3, 1 resimden 1.
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: adım 4, 2 resimden 1. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: adım 4, 2 resimden 2.
    • While using the wrench to hold the bolt, use the screwdriver to remove the screw.
    • The leg is two separate pieces, the plastic leg and rubber stopper.
    • Careful not to lose the bolts and washers as they are very small.
Sonuç
Sun Fai Lau
588 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-7, Brown Fall 2014 USF Tampa, Team 10-7, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G7
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 182
