Ana içeriğe geç
Watch Battery Replacement
Neye ihtiyacın var
  1. Watch  Battery Replacement, Battery: adım 1, 2 resimden 1. Watch  Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Place your watch in the watch holder, and adjust the sizing screw to the appropriate size for your watch.
    • If you do not have a holder, you can hold the watch yourself and still be able to complete the repair.
    FixBot'a Sor
    Yorum Ekle
  2. Watch  Battery Replacement: adım 2, 1 resimden 1.
    • Next, you will have to adjust the dimensions of the watch back remover tool you will use to take the watch back off. The dimensions should be set so the tool properly fits the three connection points on the back of the watch. You can do this by screwing or unscrewing the adjustment screws on the tool.
    FixBot'a Sor
    Yorum Ekle
  3. Watch  Battery Replacement: adım 3, 1 resimden 1.
    • Turn the tool counterclockwise until the back of the watch is completely off.
    • You will need to hold the watch band up while you complete this step.
    FixBot'a Sor
    Yorum Ekle
  4. Watch  Battery Replacement: adım 4, 2 resimden 1. Watch  Battery Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to carefully remove the current watch battery. Next, place the new battery in the same spot and orientation you removed the previous battery from.
    • Do not touch or remove any other piece inside of the watch.
    FixBot'a Sor
    Yorum Ekle
  5. Watch  Battery Replacement: adım 5, 1 resimden 1.
    • Place the back of the watch back on and align the watch back remover tool to the three connection points. Then, turn the tool clockwise until the back of the watch is tightly secured.
    FixBot'a Sor
    Yorum Ekle
  6. Watch  Battery Replacement: adım 6, 1 resimden 1.
    • Check the watch for proper operation and set it to the correct time.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Maria Pina
217 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 89
Her zaman: 3,060
