Ana içeriğe geç
Water Tap Perlator Replacement
Neye ihtiyacın var
  1. Water Tap Perlator Replacement, Loosen the tread: adım 1, 1 resimden 1.
    • Loosen the perlator using some water pump pliers or an appropriate sized wrench.
    • Use some folded up paper shop towel to prevent the pliers scratching up the perlator, if you want to reuse it.
  2. Water Tap Perlator Replacement, Unscrew the perlator: adım 2, 2 resimden 1. Water Tap Perlator Replacement, Unscrew the perlator: adım 2, 2 resimden 2.
    • Unscrew and remove the perlator by hand.
    • When screwing it on again just doing it finger tight will be alright, but you can also tighten it by following step one in reverse.
  3. Water Tap Perlator Replacement, Measure the tread diameter: adım 3, 1 resimden 1.
    • Measure the outer diameter of the tread.
    • Common sizes would be M18, M20, M22, M24 and M28, with M24 being the most common of the bunch.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sebastian
32.688 İtibar
71 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 45
Son 30 gün: 169
Her zaman: 6,701
