Giriş
The WaterPik water flosser is a widely used and popular device for dental hygeine. It is a very simple and straightforward tool used for oral hygiene. Unlike the conventional method of flossing using dental floss the WaterPik uses pressurized water to clean between your teeth and the rest of your mouth. The device relies on a pump to move the water to the handheld wand that is used by the user to clean their mouth. Over time the seals on the pump can begin to degrade and cause leaks between the pieces of the machine. This guide walks through the o-ring replacement from start to finish by explaining the various steps and possible problems along the way and thus ensuring a sucessful repair.
Neye ihtiyacın var
Make sure the Waterpik is unplugged and away from any electrical outlet.
Remove top tool tray and water tank.
Laying the unit over on its back remove the four #1 Phillips 6mm screws.
Using a flattip screwdriver or flat pick inserted between the plastic bezel and pressure knob gently pry the knob from main body.
Work in a circular motion around the knob carefully applying pressure until the gauge comes off by hand.
Place unit upright and remove main body from internal unit.
7 farklı kişi bu kılavuzu tamamladı.
11 Yorum
can we replace the handle of waterflosser? I tried to remove it but failed. some tips for this would be aprreciated.
The handle/hose assembly comes off as per step 2. Replacements are available
