Ana içeriğe geç
WaterPik (Wp-100W) Pressure Pump O-ring Replacement
Neye ihtiyacın var
  1. WaterPik (Wp-100W) Pressure Pump O-ring Replacement, Pressure Pump O-rings: adım 1, 1 resimden 1.
    • Make sure the Waterpik is unplugged and away from any electrical outlet.
    • To prevent electrical shock never begin repairs on device while it is plugged in.
    • Remove top tool tray and water tank.
    • Laying the unit over on its back remove the four #1 Phillips 6mm screws.
  2. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 2, 1 resimden 1.
    • Remove the two #1 Phillips 4mm screws from the pressure hose housing.
    • Using a flattip screwdriver gently pry the pressure hose housing from the base of the unit.
    • Use gentle pressure when removing pressure hose housing. Excessive force could damage unit.
  3. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 3, 1 resimden 1.
    • Using an o-ring removal tool or a small flattip screwdriver carefully remove o-ring from pressure pump housing by gently prying the o-ring over the lip of the housing.
  4. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 4, 2 resimden 1. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 4, 2 resimden 2.
    • Insert a small flattip screwdriver into the seam at the base of the unit and gently pry the lower housing from the main body.
    • Using a small punch or head of the Phillips screwdriver push through rubber nipple on lower housing.
    • May require some force to push rubber nipple through.
    • Separate lower housing from main body.
  5. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 5, 2 resimden 1. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 5, 2 resimden 2.
    • Using a flattip screwdriver or flat pick inserted between the plastic bezel and pressure knob gently pry the knob from main body.
    • Work in a circular motion around the knob carefully applying pressure until the gauge comes off by hand.
    • Excessive force can result in damage to the knob or the main body.
    • The on/off rocker switch does not need to be removed as it does not interfere with the removal of the internal unit.
    • Place unit upright and remove main body from internal unit.
  6. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 6, 2 resimden 1. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 6, 2 resimden 2.
    • Remove the three #1 Phillips 4mm screws from the Pump inlet housing.
    • Remove the pump inlet housing from the inlet tube.
  7. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 7, 2 resimden 1. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 7, 2 resimden 2.
    • Using an o-ring removal tool or small flattip screwdriver, gently pry the o-ring from the pump inlet housing.
    • Once you get the tool under the o-ring use a circular motion as you pry and the o-ring will slide off easily.
    • Using your hands roll the o-ring down the body of the inlet housing and remove.
  8. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 8, 2 resimden 1. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 8, 2 resimden 2.
    • Remove the two #1 Phillips 3mm screws from the on/off switch.
    • Remove the switch from its housing.
  9. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 9, 2 resimden 1. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 9, 2 resimden 2.
    • Locate the o-ring at the base on the inlet tube.
    • Using an o-ring removal tool or a small flattip screwdriver gently remove the o-ring from the pump inlet housing.
    • Placing the removal tool under the o-ring and against the inlet tube wall you can pull the o-ring out easily.
  10. WaterPik (Wp-100W) Pressure Pump O-ring Replacement: adım 10, 1 resimden 1.
    • Using your fingers set the new O-ring over the pump inlet housing.
    • Use the removal tool to set the new o-ring at the base of the inlet tube.
    • It is not critical that the new o-ring is placed exactly at the base of the inlet tube. As long as the o-ring is flat when the inlet housing is reinstalled it will index the lower o-ring to its proper location.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
11 Yorum
How would I know that my waterflosser needs Pressure Pump O-ring Replacement?
Elizabeth - Yanıt
can we replace the handle of waterflosser? I tried to remove it but failed. some tips for this would be aprreciated.
Elizabeth - Yanıt
The handle/hose assembly comes off as per step 2. Replacements are available
Steven Holbourne -
quel est le code couleur de la résistance, merci.
panka - Yanıt
Do you know if there is a replacement kit with the O-rings.
Robert
Bob Neal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 87
Her zaman: 11,406
