Ana içeriğe geç
Waterlogged Samsung Galaxy Grand Prime
Neye ihtiyacın var
  1. Waterlogged Samsung Galaxy Grand Prime, Waterlogged Samsung Galaxy Grand Prime: adım 1, 2 resimden 1. Waterlogged Samsung Galaxy Grand Prime, Waterlogged Samsung Galaxy Grand Prime: adım 1, 2 resimden 2.
    • Power off your waterlogged Samsung Galaxy Grand Prime to prevent potential damage to the running circuitry
    • Place the phone with its screen facing the work surface
  2. Waterlogged Samsung Galaxy Grand Prime: adım 2, 3 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 2, 3 resimden 2. Waterlogged Samsung Galaxy Grand Prime: adım 2, 3 resimden 3.
    • Position the primary back panel towards you
    • Detach the primary back panel to expose the battery in the secondary back panel
  3. Waterlogged Samsung Galaxy Grand Prime: adım 3, 3 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 3, 3 resimden 2. Waterlogged Samsung Galaxy Grand Prime: adım 3, 3 resimden 3.
    • Using a 1.5x25 millimeter Phillips head screwdriver, remove the nine 4mm screws to gain access to the inner circuitry.
    • Put the screws to the side in order to avoid misplacement
  4. Waterlogged Samsung Galaxy Grand Prime: adım 4, 3 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 4, 3 resimden 2. Waterlogged Samsung Galaxy Grand Prime: adım 4, 3 resimden 3.
    • Remove the battery to prevent damage during the process
    • Gently peel up the battery and set it aside
  5. Waterlogged Samsung Galaxy Grand Prime: adım 5, 3 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 5, 3 resimden 2. Waterlogged Samsung Galaxy Grand Prime: adım 5, 3 resimden 3.
    • Carefully peel away the screen display from the secondary back panel
    • Use a hair dryer if needed to soften adhesive
  6. Waterlogged Samsung Galaxy Grand Prime: adım 6, 3 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 6, 3 resimden 2. Waterlogged Samsung Galaxy Grand Prime: adım 6, 3 resimden 3.
    • Address areas of concern in the main frame with a small towel or cotton swab
    • Submerging both parts in a container of desiccants like silica gel for a period of time can also be another option
  7. Waterlogged Samsung Galaxy Grand Prime: adım 7, 3 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 7, 3 resimden 2. Waterlogged Samsung Galaxy Grand Prime: adım 7, 3 resimden 3.
    • Make sure that there is no remaining liquid
    • Reassemble the phone, starting with the screen and secondary back panel
    • Press in on every side until the frame clicks into place
  8. Waterlogged Samsung Galaxy Grand Prime: adım 8, 3 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 8, 3 resimden 2. Waterlogged Samsung Galaxy Grand Prime: adım 8, 3 resimden 3.
    • Retrieve the battery set aside in step 4
    • Orient it correctly so the phone can properly boot up later
    • Carefully place the battery back into its slot
  9. Waterlogged Samsung Galaxy Grand Prime: adım 9, 3 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 9, 3 resimden 2. Waterlogged Samsung Galaxy Grand Prime: adım 9, 3 resimden 3.
    • Retrieve all of the 4mm screws you put aside in Step 3
    • Using the 1.5x25 millimeter Phillips head screwdriver, tighten all 9 of the 4mm screws
    • Confirm that each screw is sufficiently tightened to ensure stability and proper function
  10. Waterlogged Samsung Galaxy Grand Prime: adım 10, 3 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 10, 3 resimden 2. Waterlogged Samsung Galaxy Grand Prime: adım 10, 3 resimden 3.
    • Bring back the primary back panel from step 2
    • Align the primary back panel with the secondary back panel, ensuring the Samsung logo is facing outward
    • Click the panels together and work your way around until all sides are securely attached
  11. Waterlogged Samsung Galaxy Grand Prime: adım 11, 2 resimden 1. Waterlogged Samsung Galaxy Grand Prime: adım 11, 2 resimden 2.
    • Charge the phone with a USB Micro-B cable so it has an initial charge when opening it back up
    • When all steps are performed correctly, the phone should power up and work as intended
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Johny Vu
241 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 360
