Ana içeriğe geç
Weinmann 605 Brakes Caliper Adjustment
Neye ihtiyacın var
  1. Weinmann 605 Brakes Caliper Adjustment, Weinmann 605 Brakes Caliper Adjustment: adım 1, 2 resimden 1. Weinmann 605 Brakes Caliper Adjustment, Weinmann 605 Brakes Caliper Adjustment: adım 1, 2 resimden 2.
    • Gently grasp the front brake lever and slowly release.
  2. Weinmann 605 Brakes Caliper Adjustment: adım 2, 2 resimden 1. Weinmann 605 Brakes Caliper Adjustment: adım 2, 2 resimden 2.
    • Screw the cable handle adjuster nuts and bolts into the brake lever.
  3. Weinmann 605 Brakes Caliper Adjustment: adım 3, 2 resimden 1. Weinmann 605 Brakes Caliper Adjustment: adım 3, 2 resimden 2.
    • Pull the brake lever, then aim the nameplate and support for cable adjuster to the mount hole on the inner brake arm.
  4. Weinmann 605 Brakes Caliper Adjustment: adım 4, 2 resimden 1. Weinmann 605 Brakes Caliper Adjustment: adım 4, 2 resimden 2.
    • Release the quick release lever.
  5. Weinmann 605 Brakes Caliper Adjustment: adım 5, 1 resimden 1.
    • Ensure the acorn nut for cable anchor bolt is properly tightened.
  6. Weinmann 605 Brakes Caliper Adjustment: adım 6, 2 resimden 1. Weinmann 605 Brakes Caliper Adjustment: adım 6, 2 resimden 2.
    • Tighten the lock nut for cable adjuster.
    • Cover the lock nut for the cable adjuster with the quick release cap.
Bitiş Çizgisi
Tyler Norman
183 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-3, Whithaus Spring 2024 UC Davis, Team 1-3, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S1G3
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 116
