Ana içeriğe geç
Weinmann VENTImotion and VENTIlogic Power Board Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
  1. Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: adım 1, 2 resimden 1. Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: adım 1, 2 resimden 2.
    • Open the Device by following these steps:
    • Open the device only with the power supply plug disconnected.
    • Place the device on a non-slip surface with the top facing downwards.
    • Remove the filter cassette from the top part of the housing
    • Undo and remove the 6 screws (34)
    • Open the bottom part of the housing (35) away to the side.
    • Undo the connecting cables for the humidifier (42) and the alarm (43)
    • You can now put the bottom part of the housing (35) to one side.
  2. Weinmann VENTImotion and VENTIlogic Power Board Replacement: adım 2, 1 resimden 1.
    • Disconnect the power board connecting cable (45) from the power board (41).
  3. Weinmann VENTImotion and VENTIlogic Power Board Replacement: adım 3, 1 resimden 1.
    • Disconnect the Motor Cable
  4. Weinmann VENTImotion and VENTIlogic Power Board Replacement: adım 4, 1 resimden 1.
    • Disconnect the O2 valve/power board connecting cable (70) from the power board.
    • Disconnect all connecting cables from the control board.
    • Remove the power board from the top part of the housing.
  5. Weinmann VENTImotion and VENTIlogic Power Board Replacement: adım 7, 1 resimden 1.
    • Take the rechargeable battery connecting cable (48) out of the groove and disconnect it from the power board (41).
  6. Weinmann VENTImotion and VENTIlogic Power Board Replacement: adım 8, 1 resimden 1.
    • Disconnect the cables of the old power board and plug them into the appropriate slots of the new power board 41:
    • –power board/control board connecting cable (46)
    • –rechargeable battery connecting cable (48)
    • –earth cable (47)
  7. Weinmann VENTImotion and VENTIlogic Power Board Replacement: adım 9, 2 resimden 1. Weinmann VENTImotion and VENTIlogic Power Board Replacement: adım 9, 2 resimden 2.
    • Connect the power board/mains supply unit connecting cable (45) to the new power board.
    • Position the new power board in the top part of the housing.
  8. Weinmann VENTImotion and VENTIlogic Power Board Replacement: adım 11, 1 resimden 1.
    • Restore the connections to the control board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emily Jacobson
288 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G19, Paton Spring 2020 Cal Poly, Team S7-G19, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G19
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 216
