Ana içeriğe geç
Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Stand: adım 1, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Stand: adım 1, 2 resimden 2.
    • Unplug the AC power connection cable.
    FixBot'a Sor
    Yorum Ekle
  2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 2, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 2, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 2, 3 resimden 3.
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
    FixBot'a Sor
    Yorum Ekle
  3. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 3, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 3, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 3, 3 resimden 3.
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
    FixBot'a Sor
    Yorum Ekle
  4. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 4, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 4, 2 resimden 2.
    • Grasp the temperature probe and pull it up to remove it from the monitor.
    FixBot'a Sor
    Yorum Ekle
  5. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 5, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 5, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
    FixBot'a Sor
    Yorum Ekle
  6. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 6, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 6, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 6, 3 resimden 3.
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
    FixBot'a Sor
    Yorum Ekle
  7. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 7, 1 resimden 1.
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
    FixBot'a Sor
    Yorum Ekle
  8. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 8, 1 resimden 1.
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
    FixBot'a Sor
    Yorum Ekle
  9. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 9, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 9, 2 resimden 2.
    • Detach any accessory USB cables from USB ports on the monitor.
    FixBot'a Sor
    Yorum Ekle
  10. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 10, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 10, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 10, 3 resimden 3.
    • Slide the monitor off of the stand tray.
    FixBot'a Sor
    Yorum Ekle
  11. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: adım 11, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: adım 11, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: adım 11, 3 resimden 3.
    • Place the monitor upside down on a clean surface.
    • Insert a coin into the slot and push to open.
    • Choose a coin that fits comfortably into the slot.
    • Remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  12. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 12, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 12, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: adım 12, 3 resimden 3.
    • Use the plastic label to remove the battery from its recess.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
kyle2
101 İtibar
1 Kılavuz yazıldı
Ekip
Team Freedom Team Freedom üyesi
Community
1 Üye
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 71
Her zaman: 3,755
