Giriş
Use this guide to remove or replace the motherboard in your Welch Allyn 6000 series Connex vital signs monitor.
PLEASE NOTE: This repair guide was developed by the iFixit team based on Welch Allyn's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Welch Allyn.
Neye ihtiyacın var
Remove the four Phillips #2 screws (labeled 14 in the service manual) from the rear housing.
Use the flat end of a spudger to "walk" the LCD cable connector (labeled J19 in the service manual) out of its socket.
Press first on one side of the connector, then the other to push it free. Be sure to press the connector itself, not the socket on the motherboard.
Pull the cable straight out of its socket.
3 farklı kişi bu kılavuzu tamamladı.
