Ana içeriğe geç
Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
    1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement, Stand: adım 1, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement, Stand: adım 1, 2 resimden 2.
      • Unplug the AC power connection cable.
      FixBot'a Sor
      Yorum Ekle
    2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 2, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 2, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 2, 3 resimden 3.
      • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
      • Always grasp the hose by the connector. Do not pull on the hose itself.
      • Pull the connector away from the connector port.
      FixBot'a Sor
      Yorum Ekle
    3. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 3, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 3, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 3, 3 resimden 3.
      • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
      • Always grasp the cable by the connector. Do not pull on the cable itself.
      FixBot'a Sor
      Yorum Ekle
    4. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 4, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 4, 2 resimden 2.
      • Grasp the temperature probe and pull it up to remove it from the monitor.
      FixBot'a Sor
      Yorum Ekle
    5. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 5, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 5, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 5, 3 resimden 3.
      • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
      FixBot'a Sor
      Yorum Ekle
    6. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 6, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 6, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 6, 3 resimden 3.
      • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
      FixBot'a Sor
      Yorum Ekle
    7. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 7, 1 resimden 1.
      • Remove the flathead screw on the USB networking door.
      • Loosen the captive Phillips #2 screw securing the monitor to the stand.
      FixBot'a Sor
      Yorum Ekle
    8. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 8, 1 resimden 1.
      • Holding the monitor securely, open the USB networking door.
      • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
      FixBot'a Sor
      Yorum Ekle
    9. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 9, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 9, 2 resimden 2.
      • Detach any accessory USB cables from USB ports on the monitor.
      FixBot'a Sor
      Yorum Ekle
    10. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 10, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 10, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 10, 3 resimden 3.
      • Slide the monitor off of the stand tray.
      FixBot'a Sor
      Yorum Ekle
    1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement, Battery: adım 11, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement, Battery: adım 11, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement, Battery: adım 11, 3 resimden 3.
      • Place the monitor upside down on a clean surface.
      • Insert a coin into the slot and push to open.
      • Choose a coin that fits comfortably into the slot.
      • Remove the battery cover.
      FixBot'a Sor
      Yorum Ekle
    2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 12, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 12, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 12, 3 resimden 3.
      • Use the plastic label to remove the battery from its recess.
      FixBot'a Sor
      Yorum Ekle
    1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement, Rear Housing: adım 13, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement, Rear Housing: adım 13, 2 resimden 2.
      • Open the communications door to access the lower left-hand rear housing screw.
      • Remove the four Phillips #2 screws (labeled 14 in the service manual) from the rear housing.
      FixBot'a Sor
      Yorum Ekle
    2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 14, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 14, 2 resimden 2.
      • With the handle/alert bar facing you, begin to lift the rear housing from the left side, holding the right side securely.
      • Do not attempt to separate the rear housing from the monitor, it is still attached with several cables.
      FixBot'a Sor
      Yorum Ekle
    3. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 15, 1 resimden 1.
      • Support the rear housing while you disconnect the cables in the following steps.
      FixBot'a Sor
      Yorum Ekle
    4. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 16, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 16, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 16, 3 resimden 3.
      • Disconnect the fan cable (labeled connector A in the service manual) from its socket in the power supply.
      FixBot'a Sor
      Yorum Ekle
    5. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 17, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 17, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 17, 3 resimden 3.
      • Unplug the small USB connector from its socket (labeled J4 in the service manual).
      FixBot'a Sor
      Yorum Ekle
    6. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 18, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 18, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 18, 3 resimden 3.
      • Disconnect the communications power cable from its socket (labeled J50 in the service manual).
      • Only pull on the connector itself and not the socket. This connection is very tight, work the connector slowly and gently.
      FixBot'a Sor
      Yorum Ekle
    7. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 19, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 19, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 19, 3 resimden 3.
      • Unplug the large USB connector from its socket (labeled J8 in the service manual).
      FixBot'a Sor
      Yorum Ekle
    8. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 20, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 20, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 20, 3 resimden 3.
      • Press the tab on the ethernet cable and unplug it from its socket (labeled J9 in the service manual).
      FixBot'a Sor
      Yorum Ekle
    9. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 21, 1 resimden 1.
      • The following connector requires two hands to disconnect. Flip the rear case over, and lay it on its back to gain access to the power supply cable.
      FixBot'a Sor
      Yorum Ekle
    10. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 22, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 22, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 22, 3 resimden 3.
      • The power supply cable is secured by an interlocking connector that must be held open to unplug the connector.
      • Insert the flat end of a spudger down into the power supply cover between the socket clip and the power supply connector.
      FixBot'a Sor
      Yorum Ekle
    11. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 23, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 23, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Rear Housing Replacement: adım 23, 3 resimden 3.
      • Grasp the power supply cable firmly and lift both it and the spudger from the channel in the power supply housing to unplug the connector.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Goldheart
477.931 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
72.912 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 1,040
