Ana içeriğe geç
Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement
Görüntüleme: 1,6 B
İstatistikleri görüntüle:
Son 24 Saat:
3
Son 7 Gün:
17
Son 30 Gün:
94
Her zaman:
1.560
Yorumlar: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Tamamlandı: 0
Hiç kimse bu kılavuzu "tamamlandı" olarak işaretlemedi. İlk mi olacaksın?
Sık Kullanılanlar: 2
2 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: Tahmin yok
Zorluk: Kolay
Use this guide to remove the Connex Vital Signs Monitor from the Welch Allen office cart stand.
PLEASE NOTE: This repair guide was developed by the iFixit team based on Welch Allyn's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Welch Allyn.
Neye ihtiyacın var
Aletler
    1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: adım 1, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: adım 1, 2 resimden 2.
      • Unplug the AC power connection cable.
      FixBot'a Sor
      Yorum Ekle
    2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 2, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 2, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 2, 3 resimden 3.
      • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
      • Always grasp the hose by the connector. Do not pull on the hose itself.
      • Pull the connector away from the connector port.
      FixBot'a Sor
      Yorum Ekle
    3. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 3, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 3, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 3, 3 resimden 3.
      • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
      • Always grasp the cable by the connector. Do not pull on the cable itself.
      FixBot'a Sor
      Yorum Ekle
    4. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 4, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 4, 2 resimden 2.
      • Grasp the temperature probe and pull it up to remove it from the monitor.
      FixBot'a Sor
      Yorum Ekle
    5. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 5, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 5, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 5, 3 resimden 3.
      • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
      FixBot'a Sor
      Yorum Ekle
    6. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 6, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 6, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 6, 3 resimden 3.
      • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
      FixBot'a Sor
      Yorum Ekle
    7. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 7, 1 resimden 1.
      • Remove the flathead screw on the USB networking door.
      • Loosen the captive Phillips #2 screw securing the monitor to the stand.
      FixBot'a Sor
      Yorum Ekle
    8. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 8, 1 resimden 1.
      • Holding the monitor securely, open the USB networking door.
      • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
      FixBot'a Sor
      Yorum Ekle
    9. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 9, 2 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 9, 2 resimden 2.
      • Detach any accessory USB cables from USB ports on the monitor.
      FixBot'a Sor
      Yorum Ekle
    10. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 10, 3 resimden 1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 10, 3 resimden 2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: adım 10, 3 resimden 3.
      • Slide the monitor off of the stand tray.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Sam Goldheart
478.594 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
72.907 adet Kılavuz yazıldı
1Rehber Yorum
Can the stand itself be disassembled?
olajide bello - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 94
Her zaman: 1,560
