Ana içeriğe geç
Wen 2307 Fan Replacement
Neye ihtiyacın var
    1. Wen 2307 Fan Replacement, Front Panel: adım 1, 1 resimden 1.
      • Unscrew the locking sleeve.
      FixBot'a Sor
      Yorum Ekle
    2. Wen 2307 Fan Replacement: adım 2, 1 resimden 1.
      • Remove the hanging clip.
      FixBot'a Sor
      Yorum Ekle
    3. Wen 2307 Fan Replacement: adım 3, 2 resimden 1. Wen 2307 Fan Replacement: adım 3, 2 resimden 2.
      • Unscrew the six 8mm PH2 screws.
      FixBot'a Sor
      Yorum Ekle
    4. Wen 2307 Fan Replacement: adım 4, 1 resimden 1.
      • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
      FixBot'a Sor
      Yorum Ekle
    5. Wen 2307 Fan Replacement: adım 5, 1 resimden 1.
      • To remove the front panel, pry the device apart while holding the device with the other hand.
      • The front panel should come out easily.
      FixBot'a Sor
      Yorum Ekle
    1. Wen 2307 Fan Replacement, Speed Adjustment Assembly: adım 6, 1 resimden 1.
      • Remove the connected wiring from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    2. Wen 2307 Fan Replacement: adım 7, 1 resimden 1.
      • Remove the single 4mm screw retaining the circuit board.
      FixBot'a Sor
      Yorum Ekle
    3. Wen 2307 Fan Replacement: adım 8, 1 resimden 1.
      • Gently pry the circuit board from the back piece.
      FixBot'a Sor
      Yorum Ekle
    1. Wen 2307 Fan Replacement, Motor: adım 9, 1 resimden 1.
      • Gently pull motor assembly out of the panel.
      FixBot'a Sor
      Yorum Ekle
    2. Wen 2307 Fan Replacement: adım 10, 1 resimden 1.
      • Motor separates into two pieces.
      FixBot'a Sor
      Yorum Ekle
    1. Wen 2307 Fan Replacement, Fan: adım 11, 1 resimden 1.
      • The fan assembly is attached to the rotor beam, it can be disassembled to change the fan by simply pulling off the pieces.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joshua Bowery
570 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-1, Eyestone Spring 2016 USF Tampa, Team 12-1, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S12G1
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Donde puedo conseguir ese motor completo?
#silencio$ - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 1,035
