Ana içeriğe geç
Wen 2307 Motor Replacement
Neye ihtiyacın var
  1. Wen 2307 Motor Replacement, Front Panel: adım 1, 1 resimden 1.
    • Unscrew the locking sleeve.
    FixBot'a Sor
    Yorum Ekle
  2. Wen 2307 Motor Replacement: adım 2, 1 resimden 1.
    • Remove the hanging clip.
    FixBot'a Sor
    Yorum Ekle
  3. Wen 2307 Motor Replacement: adım 3, 2 resimden 1. Wen 2307 Motor Replacement: adım 3, 2 resimden 2.
    • Unscrew the six 8mm PH2 screws.
    FixBot'a Sor
    Yorum Ekle
  4. Wen 2307 Motor Replacement: adım 4, 1 resimden 1.
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
    FixBot'a Sor
    Yorum Ekle
  5. Wen 2307 Motor Replacement: adım 5, 1 resimden 1.
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
    FixBot'a Sor
    Yorum Ekle
  6. Wen 2307 Motor Replacement, Speed Adjustment Assembly: adım 6, 1 resimden 1.
    • Remove the connected wiring from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  7. Wen 2307 Motor Replacement: adım 7, 1 resimden 1.
    • Remove the single 4mm screw retaining the circuit board.
    FixBot'a Sor
    Yorum Ekle
  8. Wen 2307 Motor Replacement: adım 8, 1 resimden 1.
    • Gently pry the circuit board from the back piece.
    FixBot'a Sor
    Yorum Ekle
  9. Wen 2307 Motor Replacement, Motor: adım 9, 1 resimden 1.
    • Gently pull motor assembly out of the panel.
    FixBot'a Sor
    Yorum Ekle
  10. Wen 2307 Motor Replacement: adım 10, 1 resimden 1.
    • Motor separates into two pieces.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joshua Bowery
570 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-1, Eyestone Spring 2016 USF Tampa, Team 12-1, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S12G1
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
All very well and good, but it’s impossible to buy the motor parts to replace…
Closetslave 1 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 1,158
