Ana içeriğe geç
Wen 2307 Speed Adjustment Assembly Replacement
Neye ihtiyacın var
  1. Wen 2307 Speed Adjustment Assembly Replacement, Front Panel: adım 1, 1 resimden 1.
    • Unscrew the locking sleeve.
    FixBot'a Sor
    Yorum Ekle
  2. Wen 2307 Speed Adjustment Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the hanging clip.
    FixBot'a Sor
    Yorum Ekle
  3. Wen 2307 Speed Adjustment Assembly Replacement: adım 3, 2 resimden 1. Wen 2307 Speed Adjustment Assembly Replacement: adım 3, 2 resimden 2.
    • Unscrew the six 8mm PH2 screws.
    FixBot'a Sor
    Yorum Ekle
  4. Wen 2307 Speed Adjustment Assembly Replacement: adım 4, 1 resimden 1.
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
    FixBot'a Sor
    Yorum Ekle
  5. Wen 2307 Speed Adjustment Assembly Replacement: adım 5, 1 resimden 1.
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
    FixBot'a Sor
    Yorum Ekle
  6. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: adım 6, 2 resimden 1. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: adım 6, 2 resimden 2.
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
    FixBot'a Sor
    Yorum Ekle
  7. Wen 2307 Speed Adjustment Assembly Replacement: adım 7, 1 resimden 1.
    • Remove the place boar carefully.
    FixBot'a Sor
    Yorum Ekle
  8. Wen 2307 Speed Adjustment Assembly Replacement: adım 8, 1 resimden 1.
    • Pull out the power cable connectors.
    FixBot'a Sor
    Yorum Ekle
  9. Wen 2307 Speed Adjustment Assembly Replacement: adım 9, 1 resimden 1.
    • Pull out the cord sleve for the new cable replacement.
    FixBot'a Sor
    Yorum Ekle
  10. Wen 2307 Speed Adjustment Assembly Replacement, Speed Adjustment Assembly: adım 10, 1 resimden 1.
    • Remove the connected wiring from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  11. Wen 2307 Speed Adjustment Assembly Replacement: adım 11, 1 resimden 1.
    • Remove the single 4mm screw retaining the circuit board.
    FixBot'a Sor
    Yorum Ekle
  12. Wen 2307 Speed Adjustment Assembly Replacement: adım 12, 1 resimden 1.
    • Gently pry the circuit board from the back piece.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dominick Chavez
137 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 12-1, Eyestone Spring 2016 USF Tampa, Team 12-1, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S12G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 1,171
